seat leon fr interferance noise
bigdonn
hi all i was wondering has anyone had the same problem,iv a 07 fr tdi leon i was driving at normal conditions normal speed, an every other day you can hear the engine/exhaust threw the car speakers, almost like what you would hear if you had a sub/amp in your boot, you can hear the amp running it sounds like that, once i stop my car an get out the exhaust will sake like its stuggling but it will go away after abit, any help would be much appricated plz
bigdonn
linfordfr
nardo grey
Nov 9, 2015
253
9
south yorkshire
If im understanding this right, you're getting what you think is exhaust note coming through you're speakers? ?
Well if that's the case, you got a aftermarket amp wired up? If so then its a poor earth which is actually picking up alternator whine, sounding like an engine/exhaust running.
bigdonn
No amp wired up in the car but if I had a poor earth that's how it would sound, dpf filter light isn't on the dash cluster, an there's no smoke from the exhaust an the car isn't down on power so would you rule dpf out?? Car is completely standered no remaps pod filters nothing, any help is appricated I font want to go to the mechanic to get ripped off!!
linfordfr
nardo grey
Nov 9, 2015
253
9
south yorkshire
He said it was possibly doing a regen... this wouldn't bring any light up nor affect power. Its the normal cycle for the dpf. You're thinking of a clogged dpf that would throw a light up and possibly limp mode.
regens do slightly alter the note.
Can you be any clearer on what you're problem is
vantastic84
70
www.facebook.com
As said above
When mine regens it alters the exhaust note and sounds rumbley as it's normal process for a regen!
bigdonn
The problem is the exhaust changing note, do does that mean the noise in hearing is the regen, the car automatically does it when it needs to??
