The dashboard has the flashing glow plug light as well as engine light and dpf light.
I presume the dpf will not regenerate with this fault.
I'm told I need to replace the egt sensor.
Error code is P0546 exhaust gas temperature sensor circuit high bank 1 sensor 1.
I'm having trouble finding the correct part number for this sensor and best place to buy it?
Once I done that I can then see if the dpf will regenerate if not then I'll have to do a dpf clean as well.
So first of all which sensor is it? Seems to be three.
One before turbocharger, one before dpf and one after dpf etc.
If someone can point me in the right direction of the correct part and part number that will be a great help.
Many thanks.
Many thanks.
