justin8260
Hi there,
I’m a newbee here, so hello all
I’ve just bought a Seat Ibiza GTI Cupra 2.0 16v and there are a few issues with it that I need to resolve:
The brakes veer to the left under hard braking. I’ve checked all callipers/pistons/pads/discs – all now ok. Does anyone know if these cars have a rear brake bias valve or anything similar that could be causing it and if so where is it located?
The remote central locking & normal central locking do not work (though sometimes when I push down the passenger pin the central locking system makes a low pitched whining noise whereby I think it locks the tailgate), which I have realised I'm prob going to have to just suffer.
However more importantly the passenger door outer lock barrel is now broken. It was turning 360degrees and so after unscrewing the screw - the one on the side of the door that you have to open the door to get to and take a black plastic cap off to inspect, its now in pieces. It came out and pretty much disintegrated. The barrel is now sitting in my house because I thought it would probably fall out if I left it in the door.
So there are the 3 issues:
*Passenger door outer barrel needs replaced - this is my priority.
- how should I go about fixing this? New barrel for the passenger door from either scrapyard or Seat and just get a basic key cut to fit the passenger door if I ever need to unlock/lock from outside? and just lock it from inside from now on? Which might be a task in itself because the pin that sticks up from the door panel seems to be permanently stuck down!
*Central locking not working
*Veering to left under hard braking
Has anyone got any ideas??
Many thanks,
Justin
Many thanks,
Justin
