Seat Ibiza 6F / 2020 / 1.0 ECOTSI 115 - Problems - Default with full LED optics
Jan 28, 2025
Hello,
Since the beginning of January, I have had a fault displayed on the dashboard of my 2020 Seat Ibiza Fr 6F 1.0 Ecotsi. The fault appeared while driving.
Fault: headlight site adjustment
So I ordered a case to be able to do an autoscan with VCDS (report attached):
I tried to erase the two faults, but they reappear 10 seconds later.
Note that the left full LED headlight optics were replaced two years ago following an accident (broken optics so replaced, bumper repaired and repainted, front-assist sensor replaced)
Clearly this is a problem with the front left optics but I can't find the source of the problem. (Note that the front left light in question no longer does its leveling cycle each time it is started.) The front right optics work perfectly.
I tried to connect another servomotor in place of the one in the optics that is causing the problem, but it does not move either, even when trying to remove the fault it is still the same. (I have not performed any other operation than reading and erasing the faults).
Do you have a track on which I could possibly go? Knowing that the full LED light works everything lights up, just the upgrade does not seem to work anymore
Thank you in advance
  • rapport_vcds.pdf
