Hi from Finland.
My Seat Cordoba 1999 1.6 AFT motor won't start.
No fault codes found with VCDS 1.2 Lite / Vagcom and MaxiScanner.
All started when starting the car got harder.
With gas pedal pushed it still started, even tho little bit "jumpy".
After bad starting the car still worked with no problems.
At this time, I bought new temp sensor and ignition switch without any help.
First new ignition switch was broken so I really bought 2 new ignition switches.
Then I bought new battery.
Then the real problems started and I had the car in idling at my parking spot and the car stopped. I tried to start again, but only starting motor was running. Nothing else.
I tried new coilpack, spark cables, spark plugs, distributor cap and rotor, hall-sensor, crankshaft sensor.
Also I checked timing belt timing.
I opened ecu and its looked perfect.
Immobilizer didn't give any codes and vcds gave all the perfect values for it.
Then I replaced most of relays, like the "167" fuel pump relay.
Tried to check all wires etc but didnt see any damaged wires.
Also opened throttle body and cleaned it.
1 hose was damaged and I think the problem of bad starting before the big problem was there.
When I use key in the first ignition position, I can hear the fuel pump sound,
Then in starting mode the fuel pump runs smoothly and you can smell gasoline.
Checked spark. It will give only 1 spark even you try to start very long time.
Then I bought all new parts again, new coilpacks, distributor cap and rotor etc and no effect.
Tried to give straight +12V to coilpack and also better ground.
Also tried to give good ground with starter cables to motor and ecu and etc.
So the problem is that starting motor is running, and it is getting fuel but only bad spark.
If I try straight to coilpack, it will give spark also from there. But only 1 spark even with long starting. It gives the same 1 spark with all the cables, and also tested with sparkcable and screwdriver 1mm from ground spot.
Still 1 spark???
Is there any measurement values to check new crankshaft and hall-sensor?
Should engine give rpm values when trying to start?
I've been on my own with this like 3 weeks as nobody in Finland seems to know what to do.. Tried to also google with mk3 golf problems but no similarity found else than this
forums.vwvortex.com/showthread.php?5924409-MK3-Golf-won-t-start-Cranks-but-no-spark-OBD2
nickname donny8155 had same kind of problem but there was no solutions told.
Hope you guys can help me!
Thank you!
Still 1 spark???
Thank you!
