If the Brembo equipped
Ateca takes a 19” rim, then they’ll certainly fit over the disc and calliper. You’ll need to check the ET value on the standard
Ateca Brembo wheels, but if there is a clearance issue over the face of the calliper you can (assuming you‘re in the UK) fit spacers to move the wheel inner face out a few mm. Likely you’ll not need them, but clearance may well be only 4-5mm and you may feel more comfortable with more clearance. Oh, if you do go the route of spacers, do make sure you buy longer wheel bolts too.
i find this site very helpful.
https://www.willtheyfit.com/
