Got a problem I think!
I have a screeching noise coming from somewhere in the engine which I can hear through the bulk head! So obviously I'm presuming turbo especially when it only occurs when turbo is on full boost past 5,000rpm! Car is running fine and VAG-COM is showing nothing out of the ordinary (Still meeting boost etc.) I have had to TIP off and had a spin of the compressor wheel and all is ok there!
So i'm kinda puzzled I have only just noticed it as I always have the radio on so couldn't hear it, but recently disconnected the battery and didn't have the code for the radio to hand so have been driving around without!
One thing I thought it may be is the wastegate creeping open abit! (Can this Happen?) As past 5k Wastgate duty cycle is at max so wastegate should be fully closed! It is even more apparent in 1st & 2nd where revs build very quickly!
The screeching noise is similar to the noise when boost is build in a high gear (4th 5th etc) from low revs! Which I have been told is air resonating in the compressor housing! (Or something ) The severty of the noise changes, sometimes you can barily hear it!
What you guys reckon?
