S3 VAGCOM results
Simon L
Audi TTS
Sep 24, 2004
1,253
Glasgow
Logged a local guys remapped S3 last night, and couldnt see anything obviously wrong with it... (other than when we had a blast i was lifting off sitting behind him and walked past high up the rev range)
- act VS req boost is fine, peaks at 19psi @ 3K and holds 14psi to 7k
- the intake temps arent too bad, peak at 42
- MAF peaks at 183 g/s
- N75 duty sits around 75%
The only thing i could think is maybe the MAF is reading a bit low? Unsure if remapped S3's should be making more than 183g/s. I think its around 240bhp, using the g/s to BHP ratio.
acidstrato
My Fast says shut up!
Dec 9, 2004
5,942
Newport, South Wales
im sure a remapped k04 motor should be seeing over 200g/s air flow
and depending on the map...WG duty should be much higher than 75%, its like the turbo is hardly trying
Simon L
Audi TTS
Sep 24, 2004
1,253
Glasgow
I noticed that too, its making requested boost without really trying, showing there is room to wind up the boost.
StarPerformance remap, Jim typically dials in low boost. Same with my map.
