RWD or 4WD SEAT Ibiza
dansheep13
Has anyone attempted or succeeded in changing a front wheel drive ibiza into either a rear wheel drive or 4 wheel drive version. Would this benefit the car in terms or handling etc. and would anyone say it was better or worse in these different versions? Any views? Also how hard would it be to do so if it's worth it?
WeeJase
pert
Jun 2, 2001
8,595
in mk2 form there is a RWD version of the ibiza.
but to call it an ibiza is like calling me a 6ft tall handsome hunk of a man.
search for max_torque
Beaker™
Slightly Unhinged........
Nov 21, 2005
1,900
C:\UK\Glos
As with anything, if you put enough money into it, it could be done. But, in this case the time/effort/cost far out weighs the end result.
In short fr 4WD, your looking at welding in a new floor with fabricated tunnel, more than likely custom running gear inc drivesahfts, moving the fuel tank, probably re routing the exhaust and new gearbox? Or somehow getting the drive to the rear wheels from the standard gearbox. And more than likely a million other things too.
Not much change from 9-10k i wouldn't have thought. And you'll probably find it hard to get anyone to give you an accurate quote before the jobs done. Sell up and buy an S3 or Golf 4motion etc if 4WD VAG is what your after. If however your dead set on a 4WD Ibiza then be prepared to spend thousands and never ever make any of it back when selling.
