running issues. real bad
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
got 1 or 2 issues at the minute
1.whining noise, the cambelt area sounds rough as a tractor
2.engine making loudish ticking noise when im under the bonnet
3.loud whistle on full boost
crap cv joint
steering feels shite
and today abs/tc light came on.....grrh
done logs on vagcom and had high correction factors, which seem to be getting better now
on number 1 would a worn tensioner bearing give a loud whine on acceleration and judging by the tractor sound coming from under the cam cover these are shot??
number 2..whats the verdict on ticking noise, not coming from the carbon canister area??
number 3, noticed today, from the n249 bypass the hose that originally went to the dv top has slight air leak, if i plug with finger it stops... any ideas what issues this could cause me?? IE noise on boost, rough running etc etc?
cv joint will be done no isssues
any theories on the steering? maybe worn rack bush?
pissed off with the cupra at the minute tbh.
moan moan:ban:
james walker
May 24, 2007
5,121
retford notts
it is bloody noisey tbh.
could be causing the ticking. sounds like its coming from the block though, coilpack area?
what issues could the n249 bypass pipe create guys?
wayne lcr
bored of it now
Mar 5, 2009
4,548
doncaster
not blowing mine own tumpet my n249 by pass sound dont think every 1 would do it if it was trouble cos nearly every 1 as and thats alot of moneys worth of cars
james walker
May 24, 2007
5,121
retford notts
p.s is it worth just changing the tensioner? i know the cam has to come off, but its way way off replacement date yet... thinking of labour costs tbh
traumapat
Leon Cupra IHI
Jul 24, 2005
5,925
sunny sussex
id do the lot unless its silly cheap to just do tensioner. too important.
Ive known a few struggle with n249 bypass but nothing ticky lol
james walker
May 24, 2007
5,121
retford notts
i know i know, im gonna do the whole change.
n249, its the pipe that you remove from the top of the dv and plug...
hissing and air escaping from this plug. so obviously not plugged correctly.
any ideas what issues this may cause and what pipe it is that ets blanked off??
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
Are you sure you've done this right.
The DV needs it's vac supply to lift it.
My DV was liked to a supply under the intake manifold
mikeholroyd
I wouldn't even think of just having a cambelt tensioner done. By the time you've had labour to sort that out, you might as well have had a full kit as well. And there's peace of mind knowing everything will be OK afterwards.
Also, you said it's not time for cambelt change yet, but when it is, that's ANOTHER tensioner you'd have to replace at that time.
Nah, you'd be throwing your cash away by only doing half a job
Mike
