yeh, i didnt cut or remove a thing in the end,
with the h/u out, look throught the hole in the dash where it would be, and you can see the drivers foot well, feed it through there, then you can pull the cable to the storage infront of the gear stick, very easy..
i now have a nother
problem....
I hooked it all up before I stuck is in perminantly, and it was working fine... now i got it in, which wasnt as easy as i hoped, as it didnt quite seem to fit in length ways with all the cables.... the speakers no longer work... well... there is no sounds... it says its playing, volume on high... and no fooking sound!!!!!
I'll have a trip to the hi-fi centre later... grrr
