vxh29
This query concerns guidance in the owner's manual in relation to running-in and checking the oil level on the VAG twincharged 1.4 petrol engine. It stems from the somewhat vague guidance given for the Skoda vRS as a result of which I would like to know what the related Seat Ibiza Cupra 1.4 TSI Owner's manual says.
The Skoda vRS manual reads as follows:
Running-in - The engine has to be run in during the first 1,500 kilometres.
Up to 1,000 kilometres:
During the first operating hours the engine has higher internal friction than later until all of the moving parts have harmonized. The driving style which you adopt during the first 1,500 kilometres plays a decisive part in the success of running in your car.
Checking the oil level
The manual also says:
"It is normal for the engine to consume oil. The oil consumption may be as much as 0.5L / 1,000 km depending on your style of driving and the conditions under which you operate the vehicle. Consumption may be slightly higher than this during the first 5,000 kilometres. One should therefore check the oil level at regular intervals, preferably every time after the fuel tank is filled or after driving for long stretches."
There is no indication as to what "style of driving" and "operating conditions" increase oil consumption but I would guess that driving your car as if you stole it and/or lots of short journeys where the engine doesn't have a chance to reach optimum operating temperature might feature?
Since you are advised to wait a few minutes until the oil has flowed back into the sump I have no idea why the oil temperature matters one way or the other?
How do these two pieces of guidance compare with what is contained in the manual for the Seat Ibiza Cupra twincharged 1.4 engine?
Please don't bother to mention your personal opinion on running-in and/or checking the oil level; I know that some people maintain that there is no longer a need to run-in a new engine and that there are heated debates as to whether you should check the oil level when the engine is hot or cold - I am only interested in the manufacturer's advice.
Many thanks for any feedback
- Do not drive faster than 3/4 of the maximum speed of the gear in use, i.e. 3/4 of the maximum permissible engine speed.
- No full throttle.
- Avoid high engine speeds.
- Do not tow a trailer.
- Gradually increase the power output of the engine up to the full speed of the gear engaged, i.e. up to the maximum permissible engine speed.
- Ensure that the vehicle is positioned on a level surface and the engine has reached its operating temperature.
- Switch off the engine.
- Open the bonnet.
- Wait a few minutes until the engine oil flows back into the oil sump and remove the dipstick.
- Wipe the dipstick with a clean cloth and insert it again to the stop.
- Then pull out the dipstick again and check the oil level.
