Ruling out my MAF; something is sticking (DV / N75 related?)
Russellg911
Hi
I posted a thread a few days ago about my car having intermittent episodes of feerling held back. I have dedicated this weekend to trying to get closer to identifying the problem.
Initially the thoughts were that the MAF may have been the problem but my findings today may point to something else. Basically I think the problem is that something somewhere is sticking. If I cruise along and maintain a steady speed so the revs are around 2.2krpm and then gradually plant my foot, the car will do one of two things:
1) You get the distinctive surge of boost / torque at around 2.5k rpm and you can hear the whistle sucking sound and the car pulls swiftyly to 5k rpm +
2) There is no 'distinctive' surge of boost / torque at around 2.5k rpm and the car will feel held back (almost constipated) through to the upper revs. You then have to ease of the gas so the revs drop back to around 2.5k rpm and then apply the throttle again - 9 times out of 10 you then get the surge of the turbo again and the car will pull cleanly towards the redline. Sometimes when in the upper revs and the car is feeling held back you will get a sudden 'pop' like something has become unstuck or unblocked and then all is fine again and the car whizzes off...it's this latter point that is making me think my fault is mechanical as opposed to a misreading sensor.
I'm certain that this is not turbo lag as in one instance today the car would not go past 4k rpm for a few seconds (I was overtaking at the time) so I just held the throttle steady, and then there was a sudden pop / snap of boost and all was well again.
Could the above point towards an N75 or DV problem?? I would note that when the car is feeling bad, the throttle bite seems to be really long when pulling away in first and sometimes it will almost dip into a stall as you pull away (done this twice today).
Russellg911
Hi Steve
Thanks for replying. My car has been vac-com'd twice and no faults ever logged. Can I ask if that's an educated guess about the coils or just a gut feeling mate??....is there something specific out of what I have mentioned which points towards the coils being the issue??
cupra-c_ya
I love da boost!
Oct 4, 2004
716
devon
img124.imageshack.us
would coil packs chuck up a fault code, I dont think the N75 valve does chuck up a code, maybe try the N75 valve as will be cheaper then replacing all the coil packs.
is your car still under warranty?
Russellg911
I should metion that on the 2 times my car has been vagcom'd the car has been running well on those days.
CupraSteve
790
i have a spare n75 thats brand new that works i can send you to try, got to have it back tho, and CupraUK no its not yours lol, iv posted yours back now
Russellg911
Steve - is it easy to fit??? :)
Minxy - you busted me there :D...how comes you're on here?
CupraSteve
790
takes about 3 mins, i just pulled the old pipes off clips and all and pushed em back on, they hold tight enuff
yyoul see it as soon as you take the cover off
Russellg911
Steve; that sounds great mate....I assume the N75 is a generic part for the VAG turbo lumps then. Deffo interested in your proposition mate..
Minxy : SSC reunited indeed :D....hope you're enjoying the Ibiza :)
cupra-c_ya
I love da boost!
Oct 4, 2004
716
devon
looks like this matey
Russellg911
Cheers C_Ya
Aha, I know where that part is...right near the DV....does it comprise of a solenoid??
CupraSteve
790
yep solenoid, just pm me your addy if u want it
Russellg911
Cheers :) looks quite easy there.
One other thing I've noticed....If I drive my car from a cold engine start, it will generally run ropey the whole journey, however long that be. However, if I let the car idle for about 10 mins and then turn off + restart, the car tends to be fine from the get go and for pretty much most of the journey...it's a lot smoother and seems to be more responive and free revving....unsure if this is connected with the problem?
