has anyones roof mouldings started to come up at the rear..
what have you used to stick them down ?
and also do they leak water ?
Im guessing your mouldings are colour coded then mate? Id imagine they come black as new.
New clips hmmmmm you might get a funny look in the stealers lol i cant imagine the strip would be to expensive, but then obviously paint etc.
If you use something like hot glue or silicone, it would be easier to pop it out if you ever needed a roof rack?
Failing that, glue the beasty in!
Jimski
Standard silicone should be fine mate, its the flexible rubber like quality that will allow it to not only stick it down, but also peel off.
Hot glue is that glue gun, with the sticks of hard glue you feed into the gun, bit of a faff and messy, few dabs of clear silicone will do the job nicely!
Jimski
I was looking at replacing both of mine but at £160 EACH + Vat I decided not to.
