Rob + Kelz Black Mk1 Leon Cupra 4WD Quattro Project
Aug 27, 2012
581
Maidstone, Kent
CURRENT MODS
ENGINE
3" Downpipe and sports/decat
Cobra sport 2.5" cat back system (non-resonated)
N249 Bypass
80mm Jetex filter + heat shield
Forge Turbo Intake Pipe(TIP)
Samco intercooler to inlet
Samco N75 lines
Forge Split R DV (Soon to be replaced for a 007p)
Samco turbo outlet pipe
Front mount intercooler 600x300x76 (Wellycooler)
TRANSMISSION
Standard dual mass flywheel + LUK clutch
02M 4WD Gearbox with Transfer box
INTERIOR
Nomad A pillar gauge pod + Auto gauges boost gauge
4WD CONVERSION NOW IN PROGRESS - PAGE 5!
A3 Quattro/S3 Rear Subframe + Diff
Adjustable Tie Arms
Fully Powerflex rear subframe
Coilover Suspension kit
LCR Front anti-roll bar
Just some pics of my leon cupra
581
Maidstone, Kent
Going to sort out a TIP and some other pipes and a 80mm jetex filter with heatshield and a 80-70 reducer to fit it to my cupra maf
aswel as a nomad gauge pod! :)
and maybe a 3" downpipe and decat then a cobra system
Aug 27, 2012
581
Maidstone, Kent
Aug 27, 2012
581
Maidstone, Kent
Fitted some new pipes on the engine bay today will post up some pics tomorrow!!
Also hoping my nomad gauge pod will be here Friday as there have been some issues with my card as their system kept declining it lol
Aug 27, 2012
581
Maidstone, Kent
Looking nice mate, good job with the inlet manifold, what did you use to clean it up? Also what does the bypass thing do? Lovely motor bud :)
Thanks, not quiet finished with the inlet yet but I used different grades of wet and dry ranging from 260 up to 1000 or 1200 so starting rough and then getting finer then give it a polish with some metal polish :D
The bypass is supposed to help hold boost a little better and stronger didn't seem to make much difference to me but that may be due to my split PCV pipe that I'm waiting to replace :(
Aug 27, 2012
581
Maidstone, Kent
All fitted... Just need to get the heat shield now, also I have got a battery cover to pick up was fed up bidding so got a new one from seat for £11.57 lol
Aug 27, 2012
581
Maidstone, Kent
Got myself a new battery cover from the stealers £11.86 new
And today I got new glove box handle and mech not so cheap, £34.40!
This is what the previous owner had done, they found how t use super glue!
Aug 27, 2012
581
Maidstone, Kent
Thought I would add a little update, I got the cover yesterday for the loom in the engine bay and I put the relays inside with the loom too
Will get some pics soon of the bay, At the moment I'm just trying to make the bay area look nice and clean
Updated the first post aswell to show current mods and plans
Aug 27, 2012
581
Maidstone, Kent
Thought I would add a little update for my latest addition to my mods, yet to be fitted yet tho obviously lol... Most likely fit it after Xmas now due to lack of time...
Large Intercooler 600x300x76
Also a new lower dipstick part as mine snapped lol
Sent from my iPad using Tapatalk HD
