Road Angel Wired To Interior Light help
s1ggm
Just hard wired my Road Angel 2 into the interior light, it works a treat, ran the cable straight up the A Pillar into the roof liner and into the light unit
Only problem i have is when i turn the engine off and lock the car the road angel stays on
Any ideas, i wanted to wire it to the Cigarette lighter but i couldnt get to it after an hour are rarving around!
Im assuming the only way round this is sticking a switch in some where? any advice would be appreciated
By the way is a Mk4 Cupra TDi
s1ggm
im hopeless at stuff like that and i didnt want to F***K anything up, little knowledge being dangerous and all
Triple D
I would also like to know haow to hardwire the road angel as i currently have it running into the cigarette lighter and have to take it out everytime i turn the car off, and it also looks messy having the cable up and over the dash.
Has anyone done or know of a guide of how to harwire it to the ignition?
VRStu
Briskodian
Mar 22, 2005
135
Hampshire
www.fabia-vrs.com
You need to identify a switched live.
Buy yourself a cheap digital multimeter - Maplins do a nice one for around £8.
Off of the radio is normally an easy to get to switched live.
s1ggm
thanks for all the advise, i have booked it into the dealer, charging me £30 to do it
BlackFR
1,724
Not too far away
The feed to the interior light is turned off after a few minutes... saves the battery if you leave the interior light on:)
As said above, the radio is probably the best place to pick up what you're after :)
