Hi all,
Right I've bee having this issue for 10 days or so now and is progressively getting worse so need some advice.
1 - Car revs irraticly on idle.
2 - Car over revs when changing gear by about 200/300 rpm.
3 - Car is dropping boost.
Ive tried the common fault fixes, Ive checked all wiring, checked all hoses, both cleaned and replaced throttle body, replaced map sensor, checked inlet mani bolts, checked and cleaned clutch position switch, checked the fuses, checked the plugs, checked all coilpacks are seated, and reset on vagcom.
Ive got no fault codes coming up related to any of this.
Nothing has been done to the car recently so cant be any new mods causing it.
This is how it idles.
And this is how it drops boost.
Im really at a blank and beginning to lose hope and heart in the car.
Does anyone have any suggestions???
