Running HB2T5, after 5k the N75 duty starts to drop and the boost drops away. Should a K04 not be reequesting more?
Code:
Engine RPM Air Mass Flow Throttle Opening Ign. Timing Engine Speed Load req psi del psi Engine Speed Intake Temp N75 Duty Cycle Press @ Intercool
/min g/s % ° /min % /min °C % mbar
1480 29.89 59.6 20.3 1320 78.2 8.8 1.0 1320 37 95.3 1100
1360 21.97 66.3 13.5 1440 84.2 10.3 2.2 1560 34 95.3 1170
1720 31.33 83.5 15.8 1760 95.5 12.3 3.8 1800 32 95.3 1290
1960 38.47 96.5 15 2040 105.3 14.3 5.6 2120 31 95.3 1430
2240 52.17 100 15.8 2320 127.8 14.7 8.5 2440 30 84.7 1700
2560 75.19 100 13.5 2800 162.4 18.7 14.0 2880 30 80 2210
3080 112.56 100 6.8 3160 190.2 20.4 20.1 3280 30 84.7 2400
3320 122.53 100 7.5 3320 191.7 20.4 20.4 3360 30 84.3 2390
3440 128.08 100 9.8 3560 191.7 20.6 20.3 3600 30 85.1 2380
3760 138.67 100 12 3840 191.7 20.3 20.3 3920 32 84.7 2380
4040 149.94 100 12 4120 191.7 20.1 20.3 4200 34 83.9 2370
4320 160.89 100 9 4400 191.7 20.1 20.1 4520 36 83.9 2380
4600 171.56 100 9.8 4680 191.7 20.1 19.8 4800 39 83.9 2360
4880 182.25 100 8.3 5000 191.7 19.7 19.7 5080 43 86.7 2320
5200 192.75 100 10.5 5280 191.7 19.3 19.7 5360 47 85.5 2340
5440 193.83 100 8.3 5520 186.5 19.3 19.1 5600 51 87.5 2300
5680 197.92 100 6.8 5760 175.2 16.6 17.6 5840 54 81.2 2170
5920 195.33 100 12 6000 172.9 13.1 17.3 6080 57 66.7 2060
6120 175.78 100 14.3 6200 143.6 10.9 12.6 6280 60 54.1 1810
6320 161.36 92.2 13.5 6400 130.8 9.4 11.2 6480 61 15.7 1770
