Reving isuse
ChrisCurzon
4WD FTW
Apr 9, 2006
1,821
Bolton
wondering if any 1 would know what this problem is only happens when the cars warm adn beein drivign aroudn for ages doesetn hapen wiht tis cold or just wamred up
what happens is when you lift of teh acelerator the car will still keep goign as if you still got foot down only for a second or so. if you put your foot down on the cluch and lift of acelerator the revs wil go up before droping down, if your goign for it and near red line it will hit teh red line when i chaneg gear.
i know that above the clutch peddle there is some sort of switch that is haning down but not sure what this is for?
cheers
TonyK
Vodka?
Jul 16, 2006
116
Northampton
My old Escort used to do something similar to that and they changed the pentiometer on the throttle (apparently) and after that it behaved
the stig
mine does that to. does anyone have any ideas. it is really annoying and somes rubbish like i tryed to rev it like a chav.
ChrisCurzon
4WD FTW
Apr 9, 2006
1,821
Bolton
i think its the sensor near the clutch peddle as mine is banging down and when it starts doing this revving thing I press it a few times and it stops, mine just needs a new clip to put it in place maybe yours is faulty?
Have a look take the panel out under the steering wheel and you’ll see hols in your clutch peddle and accelerator there will be a white sensor with a purple clip on I think.
the stig
my clutch pedal broke the other day and needed removing to be welded and i had to take the accelerator thing off and its done it ever since. think i bent the bracket a bit tryin to get it off. maybe i will have a fiddle with it and see if it is better.
ChrisCurzon
4WD FTW
Apr 9, 2006
1,821
Bolton
yea thats what i possiably is then seems to be case with mine just cant get the dealer to give me the right thing to fix it
the stig
sorted the revin thing under the dash on the throttle controller there is a small white nut shape, give it a few turns in and it tightens up the throttle. sorted mine:clap:
Beaker™
Slightly Unhinged........
Nov 21, 2005
1,900
C:\UK\Glos
This may be related.....
Follow your clutch pedal lever up under the dash and you'll find a small white plunger switch that is resting on the clutch pedal lever itself. This switch tells the ECU that you have pushed the clutch pedal down, and the ECU in turn cuts fuel. Your switch is more than likely out of position or broken so your ECU isnt cutting the fuel when the clutch is pressed.
Check that the switch is actually there
Check that its screwed into position
Check that its plugged in
If all of the above seem ok then get yourself a new switch, part number 8DO91107A
The main problem with these switches is that they have a plastic thread which screws into a bracket under the dash. This thread gets stripped very easily and the clutch pedal lever pushes it back into the bracket which casues it to be just out of range of the pedal arm or sometimes even fall out.
If your thread is a little knackered then wrap a bit of thin tape around it to beef it up a bit.
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
Is the clutch pedal switch, is a dealer part only? or can gsf supply one? :rolleyes:
