epts2008
rule the bends
Mar 19, 2009
276
Chelmsford, Essex
Is it possible to get my revs limited on my 1.4 Leon as I can't help but thrash it to go anywhere and I know one day it's just going to say no thanks and go pop. Ideally want to limit it to 4500rpm which will save it a bit. If not I'll have to put a block of wood under the go pedal ;)
i wouldnt worry m8 i had a 1.4 leon from 29,000 to 58,000 and it lived im the red line, was still going fine when i sold it just gave it oil changes every 5,000 miles
same here, did 5,000 - 62,000 in my 1.4, always on the redline and it was still running healthily when I traded it in, aside from a bit of gearbox whine :)
buy a faster car so you dont have to completely rag it to go fast! :D
If you drive your car hard, expect bits to fail quicker. Even if you had a lower rev limiter, you'll probably 'thrash' it up to that point. As other have said, the only rev limiter you need is your right foot. I'm not sure a faster car would be the best way to go as some of your ideas has worried me if you should be on the road.
