Has anyone retrofitted LED REAR lights to their Leon which has factory normal clusters??? I'm not bothered about the FL type with the indicators in both inner and outer clusters, but would like to change the standard lights to the preFL LED inners and outers. I have no intention of retrofitting front LED headlights, as the halogens with uprated bulbs are far superior to the LEDs I had on my previous Leon - so it's REAR ONLY I'm looking at doing.
I know this involves coding changes, and I am happy doing these changes as I do have the VCDS needed, but need to know if the preFL light clusters are a direct plug in substitution for the standard units. Are the plugs and wiring the same, or do alterations need to be done.
Thanks in advance
Thanks in advance
