Retrofit facelift dynamic lights
Akrateca
Netherlands
I retrfofitted the facelift tail lights. It was a good job but again there was a failure from kufatec. Ordered the split cable but damn wat an idiots are working overthere.
Everything looks like a christmas tree nothing worked right. When i measured all i came to the solution they ****** up the cable. Positive and negative where on the wrong pins.
So i searched in the electric manual and compared the cables. After that coding was an issue. So i made a log from a module 09 from a facelift. Compared everything and finally it worked.
Wrote to Kufatec with the cable issue they only said use our program dongle otherwise we cant help you. Last week someone did a retrofit with the wiringloom and dongle from kufatec. And yes same **** as was with mine setup. He switched the cables like i did and then it worked fine.
Reactions: jt20vt and Tell
