Retrofit Bluetooth + RNS-510
uniamboman
Hi all
I have spent time reading the 'Retrofit OEM Bluetooth kit' thread in the Leon Mk2 FAQ section of this site, which has been very useful. Also the thread about fitting the MFD3 / RNS-510.
But I have a question which hopefully someone can answer definitively and quickly...
I am looking into buying a used 2008 ('58 plate) Leon FR, 2.0 TFSi, Manual. This does not have factory fitted Bluetooth or Sat Nav.
If I bought this car, and retro-fitted the OEM Bluetooth kit, plus the MFD3/RNS-510 touch screen unit, can you answer the following:
1) As the car would not have fitted the largest display in the instrument cluster, I understand this means the caller's name / number, plus sat nav directions, would not be displayed in this area?
2) Despite not having this large display, with the retrofitted Bluetooth and RNS-510, would I be able to have the 6 phone number 'speed dials' appear on the touch screen?
3) When I got a call, would the caller's name / number appear on the main touch screen?
4) Would the steering wheel mounted controls for phone and music work?
5) If I really wanted the larger instrument cluster display, could I buy this from Seat and fit it, or is this a massive DIY job?? I read that a forum member on here did this, cost him about £500 I think.
Sorry for all the questions, but the answers to each could sway my car-buying decision. I have numbered the questions to make answering them easier, but any advice is appreciated.
Thank you.
DanGB
Who need's a Diesel....
Feb 12, 2006
3,772
London
2) for the RNS510 to talk to the bluetooth system, You need the newer enhanced bluetooth unit.
5) I have retro fitted the new instrument cluster with the MFD screen. Fairly easy job. You need to take off several bits of trim on the dash area. The dealer would need to code it in though. Half hour labour.
uniamboman
Thanks Dan, I appreciate your reply.
Will PM seremotors to get a quote for a new instrument cluster...
I'll also email VRStu as I'm sure he could quote me for the complete OEM Bluetooth kit including the upgraded BT module.
uniamboman
Can anyone (DanGB?) answer this....
If I buy a '57 plate (Feb 2008) Leon FR DSG TFSi, without Bluetooth, and retro-fit the OEM Bluetooth kit and also buy a new instrument cluster with the large screen (I'm aware this will be expensive and needs programming by a dealer), will this also give me things like:
Doors open indicator image
Options like mile or km etc, change the coming home/leaving home lighting delays in 10sec increments, 3 flash indicator on/off
etc.
Also, would the car described above be a MY08 car? I have not bought the car yet so can't check the VIN or chassis number. Just wondering if I'll have the clock shift problem.
Thanks.
