Rethreading wheel bolts and where to get some!??
Smoki333
472
Wiltshire
Anyone know where i can by new wheel bolts from?
Tapered, normal length.
Also any idea how to rethread the rear hub or is it best to leave for a mechanic?
JKing
Cupra-R
Aug 9, 2003
598
Mansfield, Notts
photobucket.com
Any alloy wheel stockist should be able to sort the wheel bolts for you. Can also pick them up on ebay. Most likely have tapered if you're on aftermarket alloys.
You can buy re-threading kits but I'd recommend you leave it to the pro, you can probably drive a short distance to the garage safely with just 3 bolts in.
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
you stripped a thread?
you need a tap. M12x1.5 to maybe recover... if its pulled its new bearing assy on rear or new drive flange (and wheel bearings) if front
SWANSWAY CUPRA Dealership
