Replacing Headlight Bulb
sav-fr
95
Cannock, jun 10a m6
Help,
My passenger headlight bulb has gone, I changed the drivers one the other day no problems but with the Passenger light the battery is in the way,
What is the best way to get to the bulb?
Is just as simple as removing the battery. Or is this going to cause me a few little problems?
thanks for your help
Sav
bruceR
2,558
647
Monifieth, Dundee
Hi mate, you'll be glad to know the battery stays in place. There is a cover plate forward of the battery which is held in place by 2 screws - remove these and pull the cover upwards & off. The access is still a wee bit tight but you will be able to change the bulbs.
I changed mine a while ago for Bluevisions and were all done in no time. Hope this helps
Jan 22, 2007
2,074
some may say lala land....
thanks for this as mine went today and too bl00dy cold to change in the dark so will do at weekend. Wouldn't mind but only changed drivers week before xmas - seems a good time to invest in a HID kit (only £24 at diane-shop on ebay)
