replacing handbrake/gearsick gaiters
reilly585
28
chirk
Hopefully just a quick question, I have a 1999 pre facelift gti and the gaiter's on handbrake and gearstick look ripped and tatty. Seen some replacements on ebay just wondered if they were easy to replace. Also my exhaust is very rattly when accelerating anyone suffered similar problems:doh:
crezz
pedro motorsports
Jun 30, 2007
4,397
Woolacombe
check exhaust rubber hangers, and yep easy t o fit gaitors, i found one was slack (handbrake) and gearstick was tight, easy to do tho
reilly585
28
chirk
thanks for the advice, does handbrake just pull off? Wasnt sure how to get gearbox one over the gear knob. Had a look in haynes but couldn't find anything
abhardwaj1990
Yes, I'm licking my hand
Mar 16, 2009
3,434
Shottingham
Not sure if yours is different to mine because mines a pre facelift but the handbrake gaiter has 2 screw under a flap at the back, then it comes off, it's definitely in the haynes.
The gear knob you have to take of, just twist it till it comes off, remember lefty loosey, righty tighty ;)
ather`s
EXEO Sport & mk2 IBIZA
Sep 7, 2008
2,059
mansfield, notts
use a touch off fairy liquid on the hand brake gaiter, and i mean a touch and it will slide on alot easier. the gear knob and gaiter just unscrew and the gaiter should fold over the lip on the plastic panel around the base of it.
reilly585
28
chirk
replaced handbrake, cant remove gearstick. Am I just twisting the knob at the top and how much pressure does it need don't want to brake it
