Replacement panel filter Vs CAI
cupraian
Guys,
Just about to get my car serviced and was wondering if it's worth replacing the air filter with an aftermarket panel filter (green seems to be popular) or save some money and go for a CAI and if so which one?
Cheers:worship:
RobM
Back from the dead...
Sep 27, 2006
4,982
Southampton
CAI will definitely give more noise, but any power gains are going to be fairly insignificant.
Eat The Rich
109
Preston
www.eattherich.co.uk
I'd take the panel filter... this is only cause I'm not a big fan of 'louder' induction kits. I got my Green panel filter a few weeks ago, no noticeable difference in speed or sound (didn't expect there to be either) but it's piece of mind as it's a lot better quality than the standard one (my standard one was absolutely filthy so seemed a good time too) :)
the_prophet
Newbie
Jul 28, 2006
212
shameless bump but could always buy my ram air kit i got for sale ;), just noticed you haven't said what car you've got.
think its pretty split down the middle on peoples opinions, some choose a cai, others choose a panel and derestricted / smoothed air box, the latter obviously been the cheapest option
mattbeef
84
Sheffield
The only real thing i noticed was the pickup over 4k was better than with the paper filter on. I then later on smoothed the air box and found it did nothing at all performance wise
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
Ive got a KN tYPHOON, it had got a better respone and you hear the DV! quiet loud!( ment the DV)
cupraian
Not really bothered about more noise. Better induction flow and throttle response are the main concerns really.
Would this lead to me getting a green panel filter and some large bore induction ducting?
Thanks for the help so far guys.
RobM
Sep 27, 2006
4,982
Southampton
If flow is the priority, you have two good options, one from each camp...
The BMC CDA enclosed induction kit is one of, it not the best aftermarket filters for flow rate. It's not particularly loud - although louder than stock - and isn't as prone to heat soak as other filters. This is quite expensive though.
Or,
You can smooth your air box, fit a green panel filter and some large bore (80-100mm) ducting which gives very good results that are comparable to the BMC CDA and better than many induction kits. Heat soak isn't an issue though and you keep a semi-stock look. Induction noise will be a touch louder, but not a great deal. This is nice and cheap though at well under £100 all-in.
cupraian
Cheers for the advice everyone.
Off to peruse some shiny bits of kit now:rolleyes:
