Replacement of remap? Send ECU to tuner.
May 13, 2007
1,017
Denmark
Hi!
I've recently discovered some issues with my remap, high lambda values to be precise(0.950 across the whole boost range!)
I've discussed with the remapper and now I'm fed up with all his explanations and future plans!![:@] I want a NEW remap at a PRO!
I know there are alot more cupra r's in the UK, than where I live, and it seems like you get some good figures! (I only had 242hp).
So where can I send my ECU to, and expect to get a good result? And is it recommended at all?
Best regards,
May 13, 2007
1,017
Denmark
Ok, I guess it's OK to do the ECU tune, like Audi made the ECU when they produced the car. (I dont assume audi mapped every single car!)
I'd rather get it on the RR at the same time, but when it's not possible I have to go for the second best!
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
I have flashed REVO into a mail order ecu on a lightly modded car.. highly modded I would'nt want to do this, but generic map vs stockish car, and REVO being adjustable, you have a chance of it being right
May 13, 2007
1,017
Denmark
The specifications at the moment it just LCR 210, forge 007p, BMC SP-12(Which will be replaced of a HKS 200mm foam). Car has run 84.000 km so far.
Future plans, FMIC and 3" DP+sports cat+exhaust, so I want the switch option. (Also the benefit of going back to stock ecu is good for me)
