Steve64
Hey all,
Can anybody tell me the best way to remove the inner metal door card?
I can remove the outer door card with ease but the metal door card is more of a challenge. I've had a bash already and managed to get the thing most of the way off but it keeps sticking around the door lock area.
I have removed all the main bolts holding it on and removed the window (I'm sure there is a better way to remove the window than I used). Most the metal sheet was freely moving, but it was being held on around the lock area. I couldn't quite see what was catching so didn't want to push it.
I've had a search on the forum but can't find much info.
Any help?
Steve
ive posted up many times how to do it ;)
but as your a newbie surely 1 more time wont hurt :lol:
so you have undone all the outer 10mm bolts obviously and you have taken out the window you need to undo the 3 multi spline bolts for the door catch and also remove the outer exterior handle by removing the black cap on the side of the door and hold the undle open and undo the size 25 torx screw then pull the lock carrier off and unhook the rest off the handle unclipping the cable then the metal door pannel will pull everything out window runners catch handle mechanism ect ect
its alot easier than it sounds :) goodluck
Thanks for the information. Hopefully I'll be able to get the thing off now I know what I'm doing.
