kev25v6
I have to remove the pedal box to get it welded back up due to it cracking. The steering column seems to have to come out to get the box out. Is this right? Is there anything else holding the box in apart from a few bolts?There looks to be a couple of bolts in the top of the box and where it connects to the steering column, is this all? Do the clocks have to be moved to get the steering column out or is it just the plastic surrounds that have to be moved? I know its quite a few questions but i can find loads on here that have had the same problem or had the clutch snap but there is only a write up for removing the clutch pedal not the box. Thanks for any help you can give.
