Removing Mileage from a 1.8T setup
Apr 28, 2003
2,624
Is it possible to reduce the mileage on the 1.8T range ie tt225 lcr225. Basically clocking the car to show a lesser milage than the vehicle has done. A friend has concerns that his milage is not correct. Can anyone help with these questions..cheers.
claudefrog
683
At home
www.reallymeansounds.com
hat is digital mileage correction ?
Modern cars have electronic dashboards with digital odometer displays. The car manufacturers use these because they are cheaper to produce than a mechanical dashboard and easier to fit into the car as there is no mechanical speedometer cable. This new technology has its own problems though. Electrical pulses in the cars wiring can cause the dashboard data, which is stored internally on an EEPROM (Electrically Erasable Programmable Read Only Memory), to become corrupted.
This corruption could happen for a number of reasons:
• the vehicle battery was discharged and the vehicle had been jump started
• the dashboard may develop an electrical fault
• the dashboard may be damaged in a collision or through vandalism.
In these examples, the corruption of the information held in the EEPROM may mean that the mileage displayed on the speedo is now incorrect.
Dashboard correction may also be necessary where a replacement cluster has been purchased, either new or second hand. If it's a new one it will have zero miles on it. If it's a second hand one the mileage displayed is also likely to be different to the original thus requiring correction.
