M87NER
MATNER
Mar 11, 2007
1,338
Stoke-on-Trent
Hi,
Well basically i need to now how and difficulty out of 10 rating on how to remove the front windows from my car, as all i know so far is to take the door card off...nothing else.
Any one got some advice?
Anyb guides? --- have searched by way.. ;)
Rich
like you said mate take the door card off lower the window down half way, you will have to move the plastic cover covering your window regulator, you will see two clamps which are attached to your regulator and window, there are a 10mm bolts in each of them loosen them off (dont need to take them out) and you should be able to pull your window up and free of the claps then just lift one end up and slide out of the window guides/seals
