Jamie Boy
The lock on my driver's door recently detached from the inner mechanism due to a nut or similar coming loose (I can hear it moving about inside the door) causing the key to no longer work. I can now only lock the driver's door from inside then lock the passenger's door with the key, which is a real pain. I've tried removing the inner door panel to fix the lock, but I am having real trouble removing it. I have managed to pull one side loose by popping out the plastic fasteners, but the window handle and possibly the window seal at the top and the plastic at the wing-mirror seem to be holding it on. Can anyone advise me how to remove the window handle and the door panel cover. Also, from the space I have opened up I can see there is a plastic film over the door cavities too. Will I need to cut this? Anyone with any experience of this or similar?
