removing dials!
bally
hi guys, could anyone give me an explanation for removing the dials in my mk2 t reg ibiza please? (withou removing the dash if possible). cheers
Czechboy
Tarmac terrorist
Apr 14, 2005
1,607
Hampshire
If you do a search on here then you'll probably find your answer. But basically its along the lines of, remove 2 screws at the top of the plastic dial surround, take it off. Undo 2 more screws from side of the dials. Slide it partially out, unplug the plug at the back of the dial clusters, slide the cluster out through the steering wheel.
Done
Mig
Smithy
Old School
Jan 17, 2002
965
Hertfordshire
True^
If your mk2 has an airbag, then the dials won't slide out through the steering wheel, mine didn't, tried lots!
You'll need to remove the steering wheel to get to the dials. When you've done it once, its less than a 5min job again and again.
bally
yeah mine does have an airbag, is it much of a job to remove without it blown up in my face lol! never done this sort of thing before. cheers for you help guys!
