Removing a stubborn front wishbone bush
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
I was changing my front wishbone bushes to Powerflex.
With the wishbones off the car, I used a press to remove the big rear bushes, but I couldn't get the wishbone into the press to remove the front bushes.
I faffed about with a vice and some bits of tube for a while before giving it up as being too dangerous. A lot of hammering also produced no movement.
I then thought of drilling round the rubber and as I was getting my drill out, I spotted my holesaw set....... :think:
25mm holesaw :D
Easy :thumbup:
UncleFester
Grumpier by the day!
Apr 30, 2006
4,764
Milton Keynes
www.facebook.com
Gotta be quicker than a press and way more satisfying, you get to indulge in that child like feeling of destruction :D Last time i did anything like that was on a Metro Turbo, i hit a painted stone in the road - looked like a plastic bag at the time. Bent a lower arm in half! Only found out once i'd got the ARB out to remove the lower arm that it was all held under tension ... ended up using a block and tackle with the rope jammed in the utility room door to hold it before i could 'persuade' it to go back in. These days i'd rather pay someone and save my knuckles :)
1,261
Behind Wilko
:lol: not sure the missus would like me using our doors for that... but it worked.. top job with the holesaw too.. thats been safely filed incase needed another day :blink:
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
all cowboys in this thread lol
:lol:
Well, as one of the Cowboys.....
*Always drink upstream from the herd.
*There are three kinds of men: The ones that learn by reading. The few who learn by observation. The rest of them have to pee on the electric fence.
*If you're riding' ahead of the herd, take a look back every now and then to make sure it's still there.
*Don't squat with your spurs on.
*Never approach a bull from the front, a horse from the rear, or a fool from any direction.
:D
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
How do you get that end of the wishbone into a press Bill? I tried a load of different angles (and unsafe methods of support)
Just supported the wishbone on a tube slightly larger than the bush OD, and pressed it out from the outside - in
jpcibiza90
125
scarborough
oh cool cheers i just got some arb bushes for my ibiza mk4 n wondered what it was, didnt think it would want lube on it because that could give it movement? dont know much about suspenssion lol
jpcibiza90
125
scarborough
ah yeah just oppened it it is like copper grease, were do i put this then? around the back of the bush were the bracket is or on my arb itself or just on the bolts for the bracket when i put them back in?
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
Yup it does say that on the ELSAWIN but to get these bushes in it takes a huge amount of pressing which will displace the grease pretty quickly
