remove the I B I ZA
Apr 27, 2008
900
am going to be removing the I B I Z A from the boot today and just wanted to know whats the save and easiest way to remove it?
cheers
st10587
i only brake for cake!!!!
Oct 4, 2007
3,669
Hindhead
warm with a hair dryer andpull the badges off, then pick the rest of the tape off and polish
diss_50
MK4 IBIZA CUPRA
Aug 21, 2007
1,055
Warm water Is a good way too. Softens the adhesive pads on the back of the lettering.
diss_50
MK4 IBIZA CUPRA
Aug 21, 2007
1,055
Or you could use a screw driver to get the letters off, a piece of sandpaper to deal with the adhesive, then a brillo pad to polish. HTH ;)
stezo2k
Anjuna Monkey
Mar 15, 2008
2,804
Dudley
best way i find is warm water (just between warm and hot) and a credit card. use brasso to get rid of the adhesive.
works a treat :)
________
hot girls Cams
fr-tdi
Detailing freak!
Feb 7, 2008
853
fife, scotland
whatever you do DONT pull them.
you will more than likely pull the clearcoat off with it.
warm water and dental floss is your best bet. then some tardis to remove the leftover glue.
then re-polish and wax the bootlid
Dec 5, 2007
882
Kilmarnock, Ayrshire
works a treat :)
Brasso :shrug::lol:
Boil the kettle - let it cool down for 2-5min - pour it over the letters and get some dental floss to take off the letters.
Give the area a quick wipe/wash and a little polish helped remove anything left - took 10min max
jamesy_1820vt
it looks no bad with it off ma wee mate did it with is... and then we painted the big seat bag on the bk were u go into the boot black
L14M_T
THE JOYS OF A 1200cc
Jan 14, 2009
231
RCT, South Wales
i pried them out a little using a filler spreader and removed all the remaining adhesive tape using M600 (de-greaser) and farecla G3'ed the whole tailgate and now its asif no nameplates were ever on it! nice big smooth panel.:D
tkjeeves
Blue
Jul 13, 2008
333
oxford
First i used the Search button.... (sorry in a bad mood today)
In short, an alternative way is WD40, use librally, wait for a minute or so, then plastic card and scrap off, clean up any messy gunk afterward with your fav solvent.
fr-tdi
Detailing freak!
Feb 7, 2008
853
fife, scotland
fail.
plastic card and scraping dont go well with clear coats. some nice marring for you to polish.
sorry im in a mood aswell ;)
there are less "harsh" ways of doing this - its not rocket science.
hot water.
dental floss.
tardis.
no marring scratches.
you will need to re-wax.
how hard can it be?
tkjeeves
Blue
Jul 13, 2008
333
oxford
not sure how hard you're scraping, the solvents in the WD40 should have soften the glue and foam backing enough that you could just tear the lettering off with your nails, but that just has the tendency to just tear the foam backing leaving it just a slightly harder job to clean up afterwards...
