agentuk
I have just fixed my leaky Leon using the DIY guide posted by andy_tech, thread title: Water leak into footwell - dodgy seal info and DIY repair guide, which was most useful. Now I have to try and dry out the soggy underlay under the carpet. I have done this before but when I took out the front seats I had to disconnect the airbag cable that goes to the seat airbags. This of course meant that the airbag system deactivated and the airbag warning light came on. This then had to be reset by my garage.
I have looked through the forums to see if there is a way around this and as far as I can tell all you have to do is disconnect the battery before you disconnect the seat airbag cable. Can anyone confirm that this is what I have to do for my 03 Leon S 1.6? Also is there a maximum amount of time that the battery can be left disconnected without problems arising with, for example, the immobiliser?
Any knowledge on this would be greatly appreciated.
Agent UK.
Agent UK.
