beezaturbo
341
Staffordshire
Done plenty of searchs and read alot of threads but I cant see one with the same spec as mine. I'm after a remap and as you may recall my previos post about Jabba not wanting to do it.
Its got a ko3s turbo 4barfpr induction kit relocated to where the smic was forge 007pdv, a scorpion cat back and a laguna intercooler conversion.
After speaking to different tuners i've been told i should see between 210 to 230 bhp. can some one just try and clear a few things up for me as to which remap and what hp i',m looking at. I know its hard to say and different people have there preferances (Sp). I also know its best to have the bigger downpipe and race cat but unless i can find a second hand one like all the other mods on the car I cant aford one.
so if some one could post there views ands thoughts on the matter much appreciated, thanks in advance.
It's performance that counts. I had 221 at Westec but yet there is nothing in it with an S14 200SX @290bhp also ran at westec
Go elsewhere and I'll most likely come back with a better figure.
So if you have:-
Miltek downpipe race cat supersprint centre pipe and backbox
Forge FMIC
Forge Dump Valve
Forge TIP
4bar FPR
Dynatwist
Ko3s
Can i expect more than 230bhp?
What do the standard injectors max out at?
Why not get the DP and CAT with the remap money then save for a remap once they're on? DP makes a HUGE difference. There's no point half arsing it and not doing everything which 'should' be done.
To be honest i just cant aford wone unless theres a second hand one knocking about, all the mods except the coilovers are second hand. the exhaust was £100 the induction kit was £30 intercooler £120 inc all the pipework ko3s turbo was £150 nad i've now also got a forge tip which was £65 so as you can see a few hundred pn a dp then another few hundred ona rempa takes it to over triple my current spendings on the car, I just cant justify that sort of cash on a car i use once a week or twice if i'm lucky.
its worth it, as someone said in the thread, it makes a HUGE difference, think its the most restrictive part of the exhaust, and considering your running a ko3s turbo, i would defo get at least dp before remap, probably even race cat, might be expensive but its soooooooooooooo worth it
When i had my K03S on it ran beautifully on revo stage 1 and pulled 230 BHP and 250 IBFT. The car went very well, when i changed to revo stage 2 i was very dissapointed. Revo 1 worked well for me but i had ATP manifold and DP & CAT.
