Cheers Damo, that's an interesting read. Thanks for taking the time to write it up!The car will run on both.
BUT
RON is the bit you're interested in. Despite popular belief, the higher the RON doesn't mean a bigger bang, its about the stability of the fuel. So on a performance engine that's can be pushed harder, the engine can work at higher bhp safer.
So the engine has been tuned with 98+ fuel in mind. So if you stick 95 in it, due to the nature of fuel grades differing across countries, and in the case or Republic of Ireland only having 95, the engine will still run safely, it will just adjust the fuelling to give less power/mpg. If memory serves, the guys in Ireland running 95 where only getting 260-265hp on a Cupra 280.
Other thing worth mentioning. my MINI loved Tesco Momentum 99, was never worth V Power. So when I got my 280 that's what I ran. I think it was @AndrewJB who posted ages ago about how his car although felt fine on Momentum, the logs suggested otherwise.
So I decided to try V Power for a bit. I went from averaging 250-260 a tank, to 290-300. The better MPG was worth the extra premium (and longer journey to get it)
On the Carbon I've run V-Power from the start, sadly due to the extra weight I only average 260-270 a tank. But then it is Stage 1 etc.
This is a boring but interesting video around Ethanol in fuel, so as I have an Esso garage not tooooo far away, I may see how it runs on Esso's new premium fuel, as when away in France visiting my folks, Esso was what I used more often than not, and both cars ran really well on it despite the heat. But that mayb coincidence as it would defo be a different refinery.
This ^The car will run on both.
BUT
Sadly that video doesn't really explain what knock is, but then he does say to go find his video.Honest review on this, I had the same question for this past 6 months so I tried normal 95 for 5 months then 99 past month.
Firstly price wise it makes £6-8 difference at the most, So realistically if it made a difference which ill go through next its definitely worth the extra meal money..
Now In terms of difference, Whenever i had 95 fuel when in Sports/Cupra and putting the foot down, the way it put the power down wasn't as smooth, It struggled for a second to know what was going on then gave it the power it needed. Now with 99 i have definitely noticed the difference in how smooth the power is put down and also it feels like the full BHP is being used, Which after searching up online why it felt like this videos and forums have confirmed this is indeed the case when putting 99 compared to 95 so it does in the manual book too.
Conclusion: If you want smooth power output and want to use the whole power of the car for what its made for go for 99 RON, If you will be doing city driving 99 percent of the time and wont be kicking down or full throttling anytime soon go for 95 RON.
Also watch this technical video if you want to really know how it makes a difference:
but when it was filled with Shell UL+ it behaved a lot better, improved drivability but slightly worse economy, so using UL+ fuels on engines that were never designed to be able to be optimised running with them, really can sometimes improve things despite what the "experts" claim - seeing(driving) is believing.
Excellent insight there.my god there is a lot of crap banded about as facts on the internet
Fuel
Types of petrol
The correct grade of petrol is listed inside the fuel tank flap. The vehicle is equipped with a catalytic converter and must only be run on unleaded petrol. The petrol must comply with European Standard EN 228 or German standard DIN 51626-1 and must be unleaded. You can refuel with a maximum ethanol proportion of 10 % (E10). The types of petrol are differentiated by their octane rating (RON).
The following titles appear on the corresponding adhesive on the fuel tank flap:
Super unleaded 95 octane or normal 91 octane unleaded petrol
We recommend you use super 95 octane petrol. If this is not available: normal 91 octane petrol, with a slight decrease in power.
Super unleaded petrol with a minimum of 95 octanes
You should use super petrol with a minimum of 95 octanes. If super is not available, in an emergency you may refuel with normal 91 octane petrol. In this case only use moderate engine speeds and a light throttle. Refuel with super as soon as possible.
Super unleaded 98 octane or super 95 octane unleaded petrol
We recommend you use super plus 98 octane petrol. If this is not available: super 95 octane petrol, with a slight decrease in power. If super is not available, in an emergency you may refuel with normal 91 octane petrol. In this case only use moderate engine speeds and a light throttle. Refuel with super as soon as possible.
