Recall issue?? Anyone had this problem before??
chris_necca
hi there I was wondering if the following problem was a recall on Seat Ibizas MK4. Was using the electric Window, today and was just closing it then heard a bang then the glass dropped took it to seat and they advised this was a common problem with seat ibiza MK4. For me to get this fixed it will cost £120 surely I shouldnt have to pay if this a common fault?Has anyone else experianced this problem,any advice would be greatly appreciated.Thank you[:@] [:@]
robby71
653
91
Yorkshire, UK
it's common on MK4 Golfs - the standard regulators have plastic clips - revised versions have metal ones (you have to buy the full assembly - clips can't be bought seperate)
mrcoyote
See no evil...
Jul 26, 2004
2,624
Both the drivers and passenger window regulators were replaced under warranty on my old Mk4 Ibiza. Although my local dealer wouldn't say outright, they implied it was a fairly common problem with them...
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
plastic clips that go through the glass break
have seen a clever repair that was a hole drilled through it horizontally and a washer/split pin put back through to keep it in place
did the job
chris_necca
thank you will see what seat say as they claim my dealer may try and pass it as a goodwill then if not will try fix it myself thanks for the advice:)
AwesomeSarah
Forum Sponsor
Mar 6, 2006
727
Hi Chris
If they do a recall then it really implies that there is a fault.
So they very rarely do recalls.
Even the common maf`s and coil packs was not recalls.
But they do have parts that are covered in to another year of warranty.
Customer Care claims are common.
They do this so they dont have to recall bits.
It is also common for the Octavia`s to go too.
But if you dont get any joy from the dealer call Customer Care direct yourself
Sarah
chris_necca
thanks sarah did that and they offered to pay 50% of the charges and fitting so that isnt to bad gone down to £60 so thank you :clap:
AwesomeSarah
Forum Sponsor
Mar 6, 2006
727
Hey Chris
That is not a bad result.Well done.
I do know that if they pay 100% to the parts it comes with no warranty at all.
But if you pay a bit you get the full 2 years.
Well done :thumbup:
Sarah
