Rear Wiper / washer
chill14
Lodger
Sep 25, 2005
73
Staffordshire
I suspect that the brass pipe water pipe in the motor casing maybe either broken or breaking which will cause it to start leaking. It caused by the pipe corroding to the rest of the fixing so when the wiper moves the pipe starts to twist with it.
If it under warranty then id take it back to ypur dealer to get it checked as you could end up with water pouring out of the boot trim.
orangesprout
Cheeky !!
Apr 10, 2003
654
Dodge City, North East
what joy !
another trip to SEAT garage !
:censored:
muddyboots
Still hanging around
Oct 16, 2002
5,739
I've lost the link but a Golf owner somewhere (not off this site) did a web-guide of how to fix it, as it has the same motor & problems.
Ant FR
2,861
Kent
Bare in mind guys that washer pipes are now not covered under warranty. A dealer showed me last week the bulletin from SEAT to confirm that split hoses for the rear wash wipe are not covered on warranty as it is due to adverse weather, although on the same bulletin it advisers dealers to replace the standard hose connector with an uprated version, at customers cost. Very bad i think!!!!!!!!
mrcoyote
See no evil...
Jul 26, 2004
2,624
I had my wiper motor replaced under warranty in January. If they refuse to do it then kick up a stink and they will eventually. :)
Diablo559
Diablo
Mar 1, 2005
218
N.Ireland
afaik they put a clip on to the pipe now. i also had my pipe come apart in the side of the boot that was a b#@;?! to get at . it was just a push click jobbie
MikeO
Never say die
Mar 16, 2003
263
Scotland
diablo559
"afaik they put a clip on to the pipe now" ... I'm assuming that's just to stop the plastic pipe popping off? Rather like the joint under the bonnet goes as well.
Orangesprouts problem is a bit different. Only way to fix that, is to replace the entire wiper motor assembly, unless someone can find muddyboots do-it-yourself guide. And this I would have thought without a doubt is a warranty job (IE. Shiite/faulty design). On mine the entire thing had just corroded and broken away. (IE. nothing to do with frost damage).
orangesprout
Cheeky !!
Apr 10, 2003
654
MikeO said:
diablo559
They are going to try the washer jet first - apparently they can get damaged due to very low temps - the washer jets just pull out of spindle !
if not that they'll put a whole motor on.
MikeO
Never say die
Mar 16, 2003
263
Scotland
"apparently they can get damaged due to very low temps ". Bloody hell... does this mean we are not supposed to take the car out if it's cold :confused: I thought they tested cars these days in places like Finland to pick up on just these sorts of things!
O'well... at least it sounds like it's going to be a warranty job.
Good luck.
orangesprout
Cheeky !!
Apr 10, 2003
654
Good luck.
i work in the automotive supply chain - everything revolves around cost
save a penny here and a penny there
....but no doubt you're right
Ant FR
2,861
Kent
I work in the field of Business Funding - everything revolves around cost too and success. But we have learnt,
Pinch a penny too far and lose a fortune.:whistle:
orangesprout
Cheeky !!
Apr 10, 2003
654
where i work is same - we have crap suppliers who have cost the company lots in re-work and containment but because thay can offer a 14k per year saving thats ok!
crazy world we live in :rolleyes:
