Rear wiper for LCR Mk1
andylcr
60
Berks
Hi,
I've only been on here for a few days as only boughtt my LCR on Wednesday. Have had a good search about the rear wiper on her and all I can seem to find is details about the Skoda Fabia wiper or a VW wiper.
If i am only after a replacement wiper blade will a Bosch 16" wiper blade be ok (there is one on ebay which is supposedly for Leons. was going to include the link but its not allowing me to until after 15 posts).
Also I am tempted with the whole Fabia replacement wiper as it does look nicer however wanted to know whether people still keep the same front standard Leon wipers when they change the rear to a Fabia? And if so does it look ok or will it be noticeable that front wipers are different to rear?
Any pics of the Fabia wiper would be appreciated.
A :)
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
Woorks much better than standard to :)
ThackersLCR
141
Blackpool
Il second that! but make sure you go for the one of the hatchback fabia n NOT the estate. The difference is the little slit in the cap for your water to spray out of. As i made this mistake. As far as front ones go, aero wipers and arms off a mk4 golf do the trick. VW also do a conversion kit but all it is aero blades that fit onto your standard wiper arms. Worth is though for £20 i beleive. ebay is your friend.
Icecavern
6,214
Berkshire, UK
www.icecavern.com
No No No....
You get the Estate wiper arm, Estate wiper blade, and the hatchback bolt cover cap. The hatchback wiper is much shorter ;)
CupraString
407
West Mids
Hi,
A :)
Like you I wasn't sure about changing rear wiper but once you see a fabia rear wiper it looks much better than original. I got mine from ebay and I also bought some aero front wipers which are much better aswell.
Funkyfin2000
Black Leon Cupra R 280bhp
Oct 6, 2005
2,477
Stafford, Staffordshire
does anyone find their rear wiper squeels like an arse or jumps as it goes along sometimes? all my 3 leons with the 2 different wiper shapes as above have all done it! Very annoying!
GREG_R84
Keep right on
Oct 3, 2007
656
Tamworth
Iv had no probs with mine apart from fitting it. Had to sand the cover down as it kept popping off.
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
6Y6955707A – Fabia Estate Wiper Arm -
6Y0955425 – Fabia Estate Wiper Blade -
6Y6955435 – Fabia Hatchback Wiper Cover -
Standard one used to squeek, Fabia one is much better.
CupraString
407
West Mids
yeah mine squealed like a dutch *****! when the wiper is flat against windscreen look underneath it and you should see two metal strands, they are probably rubbing on window. i bent them up a little and it doesn't screech anymore. . .
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
I use the touran one on the rear and the proper aero ones of a golf mk4 on the front, click my pic below to see the difference :)
Passenger needs to be cut down a touch to clear the window trim.
Mine don't make any noise at all :)
Funkyfin2000
Oct 6, 2005
2,477
yeah my car has the mk4 golf conversion and what a pain in the arse that was having to cut the wipers down!!! the metal inside them is VERY tough! how do most people cut them?
Rear Wiper - only judders on the first wipe across and not always, its generally when there is a little lack of water.......its a pain in the arse....
seantdi
no smoke no poke!!
Jan 18, 2009
1,218
ireland
i have the fabia rear wiper and golf aero front wipers. both are brill...IMO the aero wipers look so much better than the kit that you fit to the standard arms
seantdi
no smoke no poke!!
Jan 18, 2009
1,218
ireland
thanks lee!!
@ funkyfin. i found it easy enough to cut! how often will you be cutting them anyway lol
andylcr
60
Berks
Lee - do you have any pics of the aeros from the outside of the car so i can see what they look like on the windscreen?
