Rear washer
Bagpuss12
15
I have a 2015 FR estate. When I try and activate my rear washer I hear the motor but no water? There is water in the reservoir and the front one works fine? Is it simply blocked or is there more to it than that?
Bagpuss12
15
Update, so I sat in the car and just pressed the rear washer continually. I eventually noticed washer fluid coming into the front passenger seat footwell under the plastic trim near the bonnet release? Also noticed a small leak coming from under the car, underneath the passenger footwell! Assuming there is a break in the pipe?
There's a connection in the pipe near the bonnet release. Next to this is your TUIL point, 3/4 12 pin connectors. Not ideal if these get wet
It's possible either a fitting has failed over time (unlikely) or your washer nozzle is blocked, pressure has built up and escaped through the weakest point in the system
Walone
1,624
454
Near Heathrow
You need to sort that ASAP! Water can get into the electrical connections behind the panel and cause a lot of problems.
