benjai
My other half bought a 53 plate Ibiza last weekend. We knew that the waser at the rear wasn't working, but I thought it would be a quick fix and nothing to worry about. A quick bit of searching revealed a disconnected pipe in the engine bay where it passes through the bulkhead. Ten minutes later and it was all fixed (but I have no skin on my knuckles!). Great I thought, job done...... Oh no - the washer fluid now drains out from behind the OSR wheel, so all I've done is moved the leak from the front to the back of the car!
Did a quick search and found this is quicte a common problem, but that usually the water is coming out of the tailgate indicating that the hose has popped off the bcak of the spray nozzle. This is definately not the case - it is definately somewhere inside the rear wing! So I have a couple of questions for you more knowledgeable than I:
Where does the pipe run from front to back (I can't see it anywhere)?
Where is the best place to get at it around the rear of the car (as there is clearly another disconnection), do I go through from the boot, behind the tail lights or take the wheel arch liner and/or bumper off?
Oh and just one other question - how can something so simple be designed so poorly?
Thanks in advance for any help.
Benjai
Benjai
