rear washer jet
b21playa
oil burner
Jan 10, 2005
544
Birmingham
Hi
since i got my car the rear washer jet never works.
i can hear the motor but not water, and the tank is topped up to the top
any ideas?
FINN
70
Northern Ireland - Belfast
This happed to mine, the pipe from the front of the car to the rear had come apart. This happened above the trim in the boot. When I tried to use the jet the water was dumped into the boot instead of onto the rear window.
b21playa
oil burner
Jan 10, 2005
544
Birmingham
ok so i need to take the plastic panel offf?
phil739
199
leicester
i found that mine didnt work when i fiited the fabia conversion
i pulled the nipple out and then tried the washer and water came out
just needed a new nipple from stealer £4
b21playa
oil burner
Jan 10, 2005
544
Birmingham
ok had the panel off today which was a nightmare to get off.
anyway pipe was pushed on right, no water in boot.
tried it with pipe not connected, and no sign of water.
I think that the pipe is blocked somewhere along the line.
is there anyway to unblock the pipe?
b21playa
oil burner
Jan 10, 2005
544
Birmingham
UPDATE
drove around and kept on pressiing the rear washer jet,and soon enough i started to hear water trinkle.
the thing is the pipe is connected and i cant find the water anywhere
where could this be leaking?
amccan10
166
Wishaw
open the boot and feel the passenger side interior. just below the bit where the parcel shelf sits.
ha ha just realised you'd posteed on seat forum too.
jok0212
Newbie
Mar 18, 2006
90
i haev the exact same problem only mine worked before i had a tv HU fitted with the tv tuner, cud u tell me how to get the panels off?? does it jus pull off, ive tried before but gived up before i break anything.
cheers
b21playa
oil burner
Jan 10, 2005
544
Birmingham
cheers
if your on about the back plastic panel, it was hard work
i tried to pull it but could bee it breaking, so i took the boot lights out, which revelaed the metal clips, which i squeezed togehter with a setof pliers and easy enough came off
now i need to take the side panel off to find out where my leak it
