Rear washer coming out in passerger footwell?!
ivorbign
When i squirt the rear washer jet it ends up in the passenger footwell which it a bit scary as it is full of electrics in there!! i know there is a common problem with the pipe in the boot but mine has given up even earlier!! haha! any ideas as to fixing this as i have no idea where the pipe is?!
Thanks Will
wenman
Red Ibiza 1.8T
Mar 28, 2009
1,094
Cheshunt
The pipe will have come off under your air box at the join.
Strange that it's coming through your passenger footwell though?
Just take your airbox off and have a butchers under there!
krussel
1,713
Hertforshire
If your diesel its quite tight in that area so make sure you have plenty of time. Your profile says you have a mk5 polo so might be a different layout. :shrug:
Good luck
ivorbign
Thanks wenman, ill give that a go at the weekend and let you know how i get on. :)
Ahh well noticed there Krussel, forgot to change that. Yeah ive got the 130 Sport now so i might shove my little brother up there!! as it is very tight haha
ivorbign
No nott yet, its seems to be half way between the bulkhead and dash. i think the previous owner must have accidently cut made a hole in it when he was feeting the amp power cable through! rather annoying!
