I am having a few issues with my rear calipers/hand brake. I have a long on-going project car and I have recently just built back up the rear end of the car. Ive rebuilt the calipers with new seals and then put new discs and pads in etc and reconnected them up but theres no brake fluid in the system as there are no front lines/calipers on the car so im not sure if this is the cause to my issues.
Basically, the issues are....when i pull the handbrake up, one side the piston clamps the disc perfectly and works well, i release the handbrake but then the piston doesnt release? The caliper stays on?
Then the other side, when the handbrake is applied, the piston comes out a little bit but not enough to clamp the disc so the handbrake doesnt work, and then when the handbrake is released, the piston goes all the way back in again.
So one side sticks on, one side doesnt work at all, ive tried adjusted the cable inside the car but it doesnt seem to be any better.
Any ideas? Maybe 2 new calipers?
