Rear Caliper Guide Pins
Jun 14, 2005
920
Northants.
Hi all,
Looking for some advice please!
The tapered of the two guide pins on both of the rear calipers (Lucas) on my Mk2 99 Ibiza cupra, have become quite corroded at the rubber boot end. One was actually seized (spelling?)!
Would it be Ok to rub these down with emery paper, grease and refit? If so what grease is best - it says "copper based" in the Haynes manual! would that be the same type copper grease you smear on mating surfaces?
Can you buy them individually without the caliper housing (£48)?
Many thanks!
Jun 14, 2005
920
Northants.
Its not to good but I think I'll rub it down, grease, refit and keep an eye on it!.
It only affects the top part of the pin behind the rubber boot and with new disks/pads I would'nt of thought this area will compress into the cylinder during braking.
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
use the ones off the same girling brakes on the ford granada
Vag ones are not seperate but ford ones are and come with the correct grease
FORD part number F6141154 (pack of 2) £8.00 + vat roughly
Jun 14, 2005
920
Northants.
Cheers Fl@pper!
I'll order those - but for now I'll have to clean up the existing pins as I'am out of time and need the car!
Out of interest do you know if the one of the two in the Ford pack has a sectional tapering like my existing pins? Not shure why but one of the two pins on each side has this, Starting thicker at the bolt end and getting marginally narrower at the opposite end in distinct stages! Also what is "the correct grease"?
Thanks!
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
its like ky jelly (so im told - lol)
more resistant to dust etc than normal copper grease and the copper grease can bind up a bit when heated
http://groups.msn.com/FLAPPERSPLANET/projectibiza.msnw?action=ShowPhoto&PhotoID=886
couple of pics - but dunno if they help
forgot to add leave the F as it's possibly part of the ford recognition listing on a kerridge parts system (local dealers use it as its multi franchise)
the actual part number 6141154 is more likely
