olly_ed0088
Hey,
I managed to get the back discs and pads on last night. I had problems with the piston, it was a sod to get back in even after opening the bleed valve.
However I have a problem now. The foot pedal goes down about twice as far as it did before. The hand break is nice and tight now as I would expect it to be with new, thick pads on so the calipers and pads are doing there job fine. I have sealed up the break fluid container in the bonnet and pressed the break pedal many times so that the break fluid pressure is up but still the pedal goes down to far.
There seams to be two levels of breaking. The initial pressure as you would expect then that fades until about twice as far down when the breaks respond as you would expect. I unscrewed the back left bleed valve to much and it fell off at one point, would this off allowed air to get in so that my problem is an air block? I am confident I did the bleed valves up tightly and I am not loosing any fluid, looking under the bonnet the level is the same and can’t see any leaks from the caliper.
I might take it down to quick fit and get them to change the fluid if that is what you guys recon it might be. Can’t be bothered to mess around in the rain and mud for the sake of about £30.
Ta
Olly
Ta
Olly
