Rear Brakes on a cupra-recomendations.
May 29, 2008
675
Aberdeenshire
....as the title suggests, my rear brakes need changing and im looking for some recomendations from you guys on what u are running? simply.....Std or upgraded?
May 29, 2008
675
Aberdeenshire
Thats why asked the qeustion.....std disks and maybe uprated pads be worth while?
Always had a thing with cars ive owned....if something breaks replace it with uprated items....where possible of course!
Whats ur set-up??
cheers for the quick reply by the way :)
teepee4bh
Returning old timer
Apr 19, 2009
203
Durham
Audi TT / Octavia VRS will fit
gives you slightly bigger disks that are vented too
techathy
^^ my name, my thought >>
Jul 9, 2009
115
Cambridge
If you're going for fast road discs & pads up front it's always worth doing the same for the rear brakes.
Keep them them standard as I think it about 40% braking on the rears.
60:40 is more typical of a track setup than a road, on the panda it was about 80:20 stock. The ideal situation for maximum braking power is that you lock the rear wheels up a fraction after the front wheels, however this is far from forgiving if you need to start braking hard mid-corner, not even ABS & ESP is likely to save you then.
R1ch85
1/4mile - 13.935 @ 100.54
Nov 9, 2006
1,675
Bristol
won't you need a whole new caliper set-up for that given that vented discs are twice as wide as solid discs? also new carriers cos the diameter is bigger?
mgrays
371
18
Aberdeen
Get the cheapest nastiest ones you can get from a motor factor; they don't work hard enough as the fronts are doing all the work so you want something that will wear fast so that the discs have a chance of keeping clean. :( Also cheap to replace when the discs rust up. There is some much bias on the front of these cars that the rears must do more like 25-30% with the AP on the front. The rears drag a little but mostly stop the back end from slipping/sliding/locking.. as at that point you spin the car.
